When I click on new clip it takes forever for TitleMotion to load. Is there a work around for this or better an actual fix? This is in Edius 4.54. Thanks in advance.
TitleMotion Problems
it works instant here
I always use the T icon above the timeline and TmPro is set as default titlerAnton Strauss
bobbyd,
Welcome fellow local user!
How much RAM is installed on your system?
Are you running Core2 (or equivalent) or P4?
Does TitleMotion open faster the 2nd time you open it or slow opening always?
Are you working from a single drive? RAID? external?
Is your version of TitleMotion current? (what is the current version?)
It sounds like a disk access thing... is there much drive activity during the 3 (painful) minuets? TitleMotion should be up in about 15 sec. the first time out, less on successive runs.Rusty Rogers | Films
Originally posted by Rusty View PostIs this advice? hummm... shortcuts aren't much help
bobbyd,Anton Strauss
Originally posted by bobbyd View PostAny other solutions out there?
I just recently had a similar problem with Digital Juice took for ever to load and some other problems in Smartsound where sliders appeared black and it happened after I loaded the latest nvidia drivers 163 series my original were 90 series.
Quicktime would not play some mov files
By either going back to the original drivers or in Quicktime changing the preferences / register / advanced tab video to "Use GUI only" fixed the problem.
Sorry I cannot comment on TMP as it is not on my computer, too troublesome.
Regards BarryLast edited by Bluetongue; 12-25-2007, 01:32 AM.Win 10HP, EDIUS WG9.4, HD Spark, Boris RED 5, VMW6, Authorworks 6, Bluff Titler, VisTitler 2.8, NEAT 3/4, Mercalli 2/4, Vitascene, Izotope RX6 Plugin, NewBlue, Trend Micro AV
Do you have another system you can try Edius/TMP with?
What all is running in the background?
Turn off anti-virus scan junk.
Try Start>Run>msconfig uncheck everything you can live without.Rusty Rogers | Films
I have 3 other systems but they are used for other things and would be too much trouble to install Edius and TMP on. I am not running anything in the background and there is no virus software running on this work station. It is used only for editing. The system is clean and virus free. Everything else runs fine except TMP. Guess I will call support after the holidays. Thanks for the input and Merry Christmas.
Tech Support???
Originally posted by bobbyd View PostI have 3 other systems but they are used for other things and would be too much trouble to install Edius and TMP on. I am not running anything in the background and there is no virus software running on this work station. It is used only for editing. The system is clean and virus free. Everything else runs fine except TMP. Guess I will call support after the holidays. Thanks for the input and Merry Christmas.
Bob
Does your system have a nvidea graphics card, and have you loaded the latest drivers. If so try this it may help, it may help anyway.
Open Quicktime
In Preferences / Register / Advanced set the Video Acceleration to GUI Only
A long shot but????
Does not work
Open Quicktime
A long shot but????
Regards Barry
Tried it and it does not work. Thanks for the input.
