Searching for a beter turning page...
  • Searching for a beter turning page...
    Here is what I have... not happy, 2 levels of page and flying.
    I just want the page turning and staying in the limit of the book
    Thanks for help
    Main System: Azus Z87 Pro, [email protected], 16gb ram, Nvidia GeForce GT 630, Windows 7 Pro 64, Samsung 840 pro, Edius 8.53.2808 WG and 9.54.6706 + NXexpress or HDspark, 2T separate video SSD.
    Thanks for help
    I have never done this in Edius, but have done similar things in other NLE software that offered more control of the page curl effects, and placing a cut to a still frame of the last frame at the termination of the curl to keep it from disappearing.
    You may be able to do the same thing with a combination of Layouter/Transform and the Page Peel, but I would personally probably do this kind of thing in something that is more robust at special effects/compositing, like Boris Red, After Effects, Fusion, etc.
      Hi:
      The simplest and probably the most timesaving way is:
      "Do it yourself" - means: Film with the camera and turn the page(s) with your hands.
      kurt
      NLE: EDIUS-X(10.34.10198)-WG; RESOLVE-18.1.4.0009 Studio
      // Read > Test > Understand
        If you use any of the GPU effects you can keyframe and hot the page at the position you like. You should also be able to hold in the 2d transition.
          Thanks for suggestions. The problem is turning pages needs the carnet... under window in a museum...
          I will have a longer look in the GPU collection (many sub folders)
            use peel out, left up and choose video A for back of page turn
              https://www.videoproductions.com.au/...e-peel-GPU.png
              Thank you Anton, it is much, much beter... there are so many in the list, it's the good one. The page fly away but it's OK.
              Do you think there is just a "turning page" that follows the angle of the middle of the carnet ?
              Thanks again because I was my nose in the production in another part of these very long production and did not find time to "search end test".
                This is why I suggested using Boris or After Effects. You can control every aspect of the effect, and make the turn stick to the spine of the book. It does take a lot of work to do this though, and you would probably have to isolate the page that you are turning from the rest of the image used as the background plate, so that it doesn't look like all the area surrounding the book is also turning.
                The effects in Edius are pretty good for basic editorial work, but when you want special effects like this, something that is designed for that kind of work is better.
                  Originally posted by kpot View Post
                  Hi:
                  kurt
                  Agreed, practical is usually easier and faster, but sometimes not the desired look, if you don't want a hand in the shot for example.
                  Of course you could also do this and pull the shot through Boris or After Effects to rotoscope the hand out, but this negates the speed gained by the practical approach.
                    Thanks for answering again....
                    Now between the 2 wich do you recommand for that "turning page".
                    Boris or After Effects. I suppose they are both "plug'in" for Edius...
                      After Effects is a stand alone program from Adobe. BorisFX / Boris RED is a standalone program from BorisFX that can also operate as a plugin in Edius. For the kind of thing you are looking to do, you would probably be better off working as a standalone program, because sometimes the plugin option with Boris can do some odd things with the way it brings media in, but at least with Boris you have the option of working either way.
                      I personally prefer Boris, when I have to do FX works, just simply because I find the controls more intuitive, and because they don't use the monthly rental/creative cloud licensing model that Adobe uses, but this might make sense financially for you if you don't anticipate using it a lot.
                      Boris has trial versions you can download and try. I would recommend RED if it is in your budget, as it includes the features of Boris Graffiti also, which can be used for 3D titling work.
                      RED is a VFX plug-in from Boris FX. Boris FX is the maker of Continuum, Sapphire, Mocha, and Mocha VR.
                      Adobe also has a trial version
                      With Adobe After Effects, the industry-standard motion graphics software, you can take any idea and make it move. Design for film, TV, video, and web.
                      In either case, there is a pretty steep learning curve to contend with.
                        Thank you Bern,
                        The price is the brake... in this case for one use.
                        The solution given by Anton is perfect for result... except the flying page wich stays esthetic anyway.
                        Thanks again for complete answer and spare of time for me.
