Layouter preview not working
  • Layouter preview not working
    The preview window of the layouter does not work. I can choose 'play', It does play, but nothing happens in the preview windows until I choose 'stop' and then it jumps to the current frame. I took an old project where I know it worked, but no luck.
    I already did a re-install (E9.1). No difference. I guess there is a setting I missed, but which one?
    Chris
    System: Gigabyte Z390 Aorus Pro, Win10, i9 9900K, 16 Gb RAM 3200MHz, M2 SSD 250Gb for OS and Edius, M2 SSD 500Gb for projectfiles, several HDD for archieving, dual screen Benq PD2700U, GTX1070, Corsair H115i Watercooling, E9.5WG, Mercalli V4, TPMG Authoring Works 5, Davinci Resolve, Sony fdr-ax700
    this is normal at this stage
    the layouter preview only updates when you scrub, has been like that for a long time
      Chris
      Hi:
      As Anton said - thats "normal".
      But if you do not choose the green play-button inside the layouter but use the right (or left) arrow-key on the keyboard then you will get both: Movement in the REC window AND in the preview window of the layouter.
      Regards kurt
      NLE: EDIUS-X(10.34.11471)-WG​​​; RESOLVE-18.6.00006 Studio
      // Read > Test > Understand
        Great tip, thank you.
        I guess I mixed this up with the preview of the mask tool. Somewhere in the back of my head there is a little voice that says: this used to work when choosing play in the layouter. But if all say I got it wrong, it must be so.
        Chris.
