Hello, any one know how i could use Boris RED with Edius?, i instal it but i didn't get it!!
For future reference regarding Boris effects packages and EDIUS compatibility:
http://www.borisfx.com/hosts/canopus/support.php
And if I remember correctly, I think after installation you should see a "Boris FX" folder in your Effects Palette. Someone want to correct me on this?
Update: Thanks, Roy!
Originally posted by Alade View PostWhy does my system lock up or behave sluggish after opening Edius with Boris Red
Go to www.borisfx.com and look in the downloads section. What version of Red do you have? They used to be pretty good about keeping stuff for older versions around, but that's changed.
About Boris Red 4.1 it work on Edius 4 but Red 3 Work on Edius 3
i managed also to activate boris continuum complete 4.1 on Edius 4 but the but 5 filters wich are bcc 4 light ( lens filter .... ect ) didnt work well anything to make it work here or other plugin then boris have light effects as lens and glitter and star glow ??
