I have a question that probably has a simple answer. When deleting a project from Edius 4.5 is there a specific order that should be followed? I usually work on Avid systems where you would go into the project bins and delete the clips, then open the media tool and delete precompute files. When I deleted media from an Edius project I still see that project name( which is greyed out) on the start up window.
Deleting projects
simply delete the project folder and learn to ignore the grayed out project. It will automatically remove itself eventually as other projects are opened
or if it gets on your nerves, there is a way to edit a certain file to remove itAnton Strauss
the solution to delete these entries is here
what does the error message say exactly?Anton Strauss
did you set an in and outpoint on the timeline?Anton Strauss
so the export to DVD software starts and then you click settings and set video to 7700 max and set audio to ac3 256
then you click style tab and choose if y6ou need a menu or not
then you click the write tab and select burn speed to 6x max after inserting DVD and waiting 30 sec
alternatively, you can tick to only make the VIDEO_TS folder and not burn at this stage, this would be my option because I burn with Nero6
at what above stage do you get the error?Anton Strauss
this could mean that your burner is not suitable for the built in burn module, what burner model do you have?
can you try compiling without burning, this will give you a VIDEO_TS and AUDIO_TS folder
then use your regular burning softwareAnton Strauss
