Edius 9 Crash while exporting to MP4 ???Help
  • Edius 9 Crash while exporting to MP4 ???Help
    Dear all
    While I am trying to export my timeline to mp4 the edius gets crashed and edius exist without continuing export and this is the first time I face such a problem althought in the past I exported longer timeline than this one . And i find a note the it means I think like this " there is a sufficient memory "
    although my pc is:
    Intel core i7 5930K 3.5 GHz
    Ram =16 GB
    SSD 256
    HDD = 4 TB
    VGA = gigabyte 6 G 980 GTX Ti
    timeline length = 3 hours ??
    help
    I would be looking for a corrupt clip. No easy fault find but try exporting the TL to HQ. If that crashes then you will need to export in sections to find the offending clip.
