What is the best way to create a square video to post on Instagram? Would you use the mask filter? Client wants to use the video I shot 16x9 and use it for instagram. Can edius squeeze the video to a 1:1 ratio so I do not need to re crop? Thanks in advance.
best way to creat 1:1 ratio for Instagram
Much better: when you setup a new project, choose one of the presetted formats and click on "extended" (or something similar sounding). There, you can define the actual project size and therefore you may set 1080x1080.
With the help of Layouter, you might then pan & scan your shots to fit into your square project.Last edited by Captain; 11-28-2017, 02:25 PM.Intel Core i7-7820X ---- Noctua NH-D15S ---- MSI X299 GAMING M7 ACK ---- 64GB RAM 2666-15 Corsair Dominator Platinum ---- 500GB Samsung 960 EVO M.2 (system SSD) ---- 512GB Samsung 960 PRO M.2 (data SSD) ---- Aorus Nvidia GTX 1080 Ti ---- be quiet! SILENT BASE 600 Case ---- be quiet! Dark P. Pro P11 850W ---- Win10 Pro ---- Edius WG 8.53.2808
