Audio Mix Preview Window
  • Audio Mix Preview Window
    Hi,
    We are using Eduis 8.53 to edit a tv show. Our transcriber is having trouble with the audio coming from the preview window. While it used to play line one on the left channel and line two on the right, it now mixes both tracks together.
    This makes it hard when trying to transcribe two different audio sources. Any ideas how to change it back to left and right?
    It only does this in the preview window. we can mix audio on the timeline fine.
    You have changed the audio monitoring mode. Go to Settings>System Settings>Application >Audio Monitoring and make sure both Player and Monitor are set to Off (you are specifically concerned with player). I am providing the location by memory, so I hope it is correct.
      Thanks for the quick reply i end up finding this option under User Settings>Preview>Monitor i ticked the Auto box and it seams to have fixed it.
        or click the audio monitoring mode switch on the top right of the VU meter
