DVX doesn't work with ATI 1950!!!
  • DVX doesn't work with ATI 1950!!!
    DVX doesn't work with ATI 1950!!! Overlay doesn't exist. When I replaced x1950 with x800xt ,dvx start work fine.
    custom PC No 1 ; mdb: Gigabyte Z68A-D3H-B3, cpu: i7 2600K, vga 1: 2x nvidia gainward GTX 670 (2GB), vga 2: intel ,ram: kingstone hyperx ddr3 16GB, sys HDD: SSD Transcend 128GB, monitors: 3x LG L225WT dvi, 1x plasma tv LG 50PK350 nle: HD SPARK, OS: windows 7 x64 ultimate
    custom PC No 2; mdb: asus P6T deluxe v2, cpu: i7 920, vga: nvidia gainward 275 (896mb), ram: kingstone hyperx ddr3 12GB, monitor: 2x LG L20WT dvi, OS: windows 7 x64 ultimate
    did you try changing the video overlay type under Edius Hardware settings?
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
      It should work. I had raptor RTX2 Max- it was working with X1950 Pro very nice. You probably changed graphic card in already installed system. You may edit Canopus.ini file or change overlay in settings with restart of system.
      mike
      Asus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
        OK. It works. Thanks.
