Have Edius 3.61 and having an issue in settings. Trying to change colors and levels for the audio mixer. Seems like Edius won't allow me to make changes. Am I missing something or has anyone have any ideas? Thanks.
Audio Mixer
Audio Mixer
Thanks,
Ara
Windows 10 Home 64 Bit, Edius WG 9.55.7303, Edius X WG 10.20.7490 Intel Z370X Motherboard, i7-8700K 4.7 GHz 6 core, 12 Thread LGA-1151 CPU, GTX-1080 8GB Graphics card, 500GB M.2 PCIe NVM SSD, 16 TB Raid 0 Media Drive, 32 GB DDR4 Memory, Intensity Pro 4K AV I/O, CS 5.51 Production Suite.Tags: None
do you mean you want to change the green yellow and red sections of the VU display in app settings customize and it won't change?
the way the mixer displays levels can be changed from the mixer itself in top right cornerAnton Strauss
Greetings Anton,
You are correct as far as the customize portion of settings. I am trying to make the first level -6db with a color of my choice and the second level is -12db with another color choice. It seems like Edius is getting hung up during the input of the db area. It freezes and it will not apply the changes I make. I hope this makes sense.Thanks,
Ara
Originally posted by mattmatt View PostI think he (or she) means that once in the audio mixer, they can't change the levels...you need to change the mode at the bottom of each lever from NONE to TRACK, LATCH, TOUCH or WRITE.Thanks,
Ara
use the mouse scroll wheel to change the db value, then click in the other db field, this should make the apply button activeAnton Strauss
Been there and done that. I wish it were that simple! This is exactly what I was doing when it froze up on me.Thanks,
Ara
I can't remember this issue in Edius 3.62 (small update from 3.61)
do you have the same problem in your 4.54?Anton Strauss
No. 4.54 is rock steady.Thanks,
Ara
