Edius 64 BIT
Paranova Films
Cali - Colombia
http://www.paranovafilms.com/
AT LAST!!
after dozens (not thousands, not hundreds, really dozens) of tests, cleans installs of xp32, xp64, vista 64 with and without filters, different project settings, intalling and no installing other programas, finally after upgrading to 5.11 my machine is not crashing any more!!!
(ups) -sorry- just 1 hour ago of testing and i'm so happy as i can... more tests (and try to solve the QT issue) and reporting here...Paranova Films
Cali - Colombia
Hmmm, I wondered why some people are facing so much problems.
Good for you, Paranova.
Now - what problems you are getting with Quicktime?TingSern
We don't need the Ultimate version. If you can get "lower" version - like BUSINESS, that will be cheaper. Just make sure it is 64 bits :-).TingSern
Originally posted by tingsern View PostHmmm, I wondered why some people are facing so much problems.
from the "5.1 won't recognize QT .mov files" post:
Originally posted by Paranova Films View Postby the time we receive our 5 i found that the QT that came with the disc didn't work (even no opnening the quicktime player) unistalling it and installing and old one solve the issue but... now i finish to install the 5.11 with same issue, tryed to made the same (uninstalling and installing another qt) didn't work: a few .mos that i am using in a project that were working fine now are offline and with no chance to restore, the curios thing is tat qt player can play thoose from the explorer... i'll download a fresh version from the page and see...
upss almost forgot it no mather the source of the files (digital juice, after effects renders, etc) some files works (in edius) and some not...
downloaded and uninstalled the previous version, intalled the new one... not even open... (i have to say that mine is XP64Bit os) so went back to my old qt 7 and still the same: some clips recognized and some others not...
and no matter if there are SD or HD clips... opening another SD project found the same issue... the strange is that when i play the clip from the explorer it plays fine, when loading again the clip to edius, it loads offline... but: when i copy the clip to a different folder or rename this one and load to edius it works...
i know that i can replace the offline clip with the new copied but there must be a resaon or a solution for the "offline clip"Paranova Films
Cali - Colombia
