Hello friends....i m using edius 8.51 ..with latest update...one of my audio clip has a noise like a fane , generators...or etc.......so is there any way to reduse this noise from audio clip with the help of edius or any other filter??
How to reduse audio noise?
As an example, I use the Wavearts Master Restoration Suite. To reduce noise on voice overs, I use MRGate_64 and MRNoise_64. These two plugins work wonders.
https://www.bhphotovideo.com/c/produ...sHAaAjCz8P8HAQ
Not a bad price when you compare it to other options.Last edited by Jerry; 06-16-2017, 01:25 PM.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.Comment
I use both. But, Wavearts is a plugin within both Audition and Edius. I think Wavearts, MRNoise along with MRGate gives me the best result in both Audition and Edius. The noise reduction is comparable, but the combination of noise reduction and an adjustable gate, makes all the difference.
You can download a fully functional demo from here:
http://wavearts.com/downloads/
This way you can judge for yourself.Jerry
