Do you need a big honkin video card to do HDV? I am capturing my 1st HDV project and I keep losing overlay during capture then I get a green screen. I think its still capturing though. I have a PNY 8500GT with 512 megs of memory. I think its a cheap 512 meg card on a quad core 2.4 should I upgrade? Also I am using the JVC GY-HD100 which capture preset should I use? Also if I got one of those fancy cards can I get HD out in addition to dual monitors?
HDV and Video cards
If by fancy card, you mean edius NX, then yes :) I'm pretty sure thats the only way you'll get proper HDV out to an external monitor.
I've edited, and captured HDV with a 256mb card and had no issues - check for latest drivers for your card :)When I go out, I wear my EDIUS T-Shirt.
if I got one of those fancy cards can I get HD out in addition to dual monitors?GA-EP45C-DSR3,Core2Q3ghz,8gig1066,260GTX,2x 20"AOC,22"Vizio1080pTV, Edius5/HDspark,PC3,Imaginate, CS5ProdStudio/IntensityPro,Win7_64
Originally posted by rando View PostDo you need a big honkin video card to do HDV? I am capturing my 1st HDV project and I keep losing overlay during capture then I get a green screen. I think its still capturing though. I have a PNY 8500GT with 512 megs of memory. I think its a cheap 512 meg card on a quad core 2.4 should I upgrade? Also I am using the JVC GY-HD100 which capture preset should I use? Also if I got one of those fancy cards can I get HD out in addition to dual monitors?
Since I have upgraded my monitors to 2 22 inch widescreen at 1680x1050 and using the left screen for FULL screen playback set to "field" update I am occasionally now having the "overlay" disappear (purple screen) when switching between sequences.
Sometimes clicking on the task bar (Windows) or going into task manager and selecting Edius again fixes the problem but sometimes Edius needs to be restarted, The latest nvideea drivers improved the situation slightly but I am upgrading to a 8800GTX to see if any improvement can be made, still waiting for it to arrive. NOTE no NX card tooo much trouble with compatibility, OK if it works OK, better to spend the money on a faster computer and other means of monitoring.
I use a DVICO A5000 on the lan to output each sequence in m2t format and then playback to a monitor / projector to check for any issues, cheaper and NO problems with compatability
I do nothing but HDV. I have a PNY NVIDIA GeForce 7600GS (256MB) video card. No problems with Edius 4.54. I capture thru the NX card.Camera: Sony HVRZ1U
Software: Edius 5.11, ProCoder 3.05.91, Imaginate 2, DVDit Pro HD
System: Supermicro X7DA8, 2 Dual-Core Xeon (5060) 3.2GHz, 4GB RAM, (ST3750640AS) 750GB x 2 SATA
7200RPM RAID 0, PNY NVIDIA GeForce 9600GT (512MB), Dell UltraSharp 2407WFP, WinXP(SP2), Edius NX w/ Bay and Expansion Kit
