Edius 4.51 print to dvd
  • Edius 4.51 print to dvd
    I have created a project edited everything ,but when i click the print to dvd it does not come up.
    Guys please can someone help me out how to start the print to dvd.
    P4 DUAL 3.0, EDIUS 4.51 WIN XP PRO
    EDIUS 9.5 /Win 10 x64 Dell T5600 INTEL Xeon 16 core @2.66GHz 32GB RAM /NVIDIA GEFORCE GTX 1660TI, SSD SAMSUNG 500GB PRIMARY, WD 5.5TB STORAGE, 2x WD500GB ASSETS, heroglyph 4.0, Sony AVCHD cam, Canon DSLRs.
    Sys 2: Asus ROG G75series
    Print to DVD
    I had the same problem. I assume you are working in PAL as I have never tried generic SD NTSC.
    The Print DVD is blanked out if you are running the project in 720x576 25p over 50i or any other 25p setting.
    To print to DVD you need your Project Settings in one of the 720x576 50i settings. You then should get print to DVD.
      There's a big difference between not launching and not being available to launch DVD creator.
      If Print To DVD is greyed out in the "Print" menu, your project settings are incorrect. Follow Androm's instructions.
      If DVD Creator won't launch after selecting Print To DVD, there is something else going wrong.
      My first thought is to re-install Edius. If you're using 4.51c, it may be better to just upgrade to a newer release (4.52 for demo, 4.54 for release).
        Well Guys I Reinstalled Edius And Got The Same Answer Print To Dvd Did Not Launch, Then I Upgraded To 4.52 But Unfortunately The Same Thing So What Should I Do Now
          What are your project settings then?
