Multi-Cam Redux
  • Multi-Cam Redux
    Hi All,
    My first post, just downloaded 4.52 - pretty cool.....but I'm having an issue with multi-cam
    Unfortunetly my laptop doesnt have a number keypad - besides for the mouse clicks is there any other way to switch between cameras? Or re-assign the keypad? I went into keyboard shortcuts and the multi-cam setting..but there doesnt seem to be a place to change that?
    having the ability to punch instead of click will make things a lot easier!
    Thanks---hope to contribute to the board soon as well!
    I'm quite shocked, I thought edius had a customizable key for everthing - seems that multicam switching is confined to the num pad only....
    Anyone prove me wrong?
      If all else fails, you could get a full-sized USB keyboard and plug that into your laptop.
        They sell USB numpads on ebay for like $10...but nonetheless I think shortcuts such as CTRL+1,2,3,4,5,6,7,8 or something in between would be nicer. Maybe there is a shortcut without numpads, but I haven't found any.
          Most laptops have it already...
          Look closely at your keyboard, there's a good chance keys are already reassigned/overridden with a "Function" key (or similar)
            Thanks for the replies...I've tried everything including the function keys....Cntl-1 etc doesnt work either.....I've thought about the usb keypad/keyboard thing and was gonna hit staples today if all else failed....just seems silly to have to hook a keyboard to a laptop....but with 4 - 2 hour 3 camera dance recitals to edit - i'd rather not have to click....
              I bought a keypad to use with my compact keyboard on my Same-Day Edit box. Really nice and has a built-in calculator.
                I use a Shuttle Pro with keys allocated to camera 1,2 etc
                They are worth looking at.
                The ShuttlePro V2 is the premier multi-media editing tool. Whether you are working in video, audio, photography, graphic design, or any creative setting the Shuttle can help maximize productivity and allow you to focus on what matters, creating.
                  You caught us out on this one.. :)
                  No keyboard remap available alas...
                    Wow--my first time out and I called out the designers... Well problem solved anyway...just went out and got a external usb keypad....works fine...only problem is I tried to re-assign the jkl keys to work with 4-5-6 so while I'm editing if I have to go back and make a minor change...wont seem to let me....grrr
                      Your numpad doesn't have a NumLock function?
                        my laptop doesnt have a number pad--I wanted to originally remap those keys to somewhere else..but I guess that can't be done---the $20 usb keypad is working just fine...it lets me sit on my couch with it next to me - I have the laptop hooked up to one of 50" plasmas and I feel like I'm directing a show with a real switcher again :-)
                          Nice. That's one thing I don't like about laptop keyboards (tho the larger ones do have full numpads nowadays)...
                            Mine has full num pad. and a cool keyboard. :)
