One of the 4 Edius 7.5 workstation PCs I have at the local cable station has suddenly stop allowing me to use the number keys in multi-cam mode. Instead it cuts using the mouse (little camera icon) hovering over the preview monitor screen. I am much more use to using the number keys, especially with 3 or 4 sources. Any suggestions how to change this cutting method back to the keyboard?
Multi-cam In Edius 7.5 number keys stopped working
Have you checked if the Numeric Lock is on. You probably know that the number keypad keys cuts to a camera only when playing, but did you know if you hold the Ctrl key down + keypad number you can cut to a camera without playing.Check out posts on this forum: Sync markers from PluralEyes version 3 or 4 http://forum.grassvalley.com/forum/s...021#post280021 Syncing by Timecode with Tentacle Sync http://forum.grassvalley.com/forum/s...330#post280330 Converting Sequence markers to Clip markers. http://forum.grassvalley.com/forum/s...898#post281898
Originally posted by Green Grass View Post.... but did you know if you hold the Ctrl key down + keypad number you can cut to a camera without playing.
In other words you do NOT need to hold down the CTRL key
Originally posted by DigitalDave View Post...and if you don't hold down the CTRL key...you can cut to a camera without playing.
In other words you do NOT need to hold down the CTRL keyCheck out posts on this forum: Sync markers from PluralEyes version 3 or 4 http://forum.grassvalley.com/forum/s...021#post280021 Syncing by Timecode with Tentacle Sync http://forum.grassvalley.com/forum/s...330#post280330 Converting Sequence markers to Clip markers. http://forum.grassvalley.com/forum/s...898#post281898
