Edius 8.3 problems framerate format and resolutions
  • Edius 8.3 problems framerate format and resolutions
    Edius 8.3 does not Recognize PSF and some resolutions.
    Example: Canon Legria 1920x1080 25 PSF.
    Edius 8.3 writes "1440x1080 progressive" (italian: progressivo)
    Edius 8.2 writes: "1920x1080 upper field" (italian:campo superiore).
    Note: i have changed the project from 50i to 25p, but the problem remains unsolved.
    Edius 8.3 does not recognize Cineform files exported from Premiere.
    Edius 8.3 does not recognize Quick Time Animation files exported from Premiere.
    I edited Cineform and Quicktime Animation in Edius 8.2. Now i cannot edit my work project in Edius 8.3 :(
    Have you tried this?
      Do you have the Cineform codec on your Edius 8.3 machine?
        Hi guys!
        Legria problem: solved. Original clips were 1440x1080, not FHD and not PSF. Who gave me the clips was wrong. He said "Full HD PSF". It's no true. I have verified with another software. Sorry.
        Quick Time problem: solved. Thank you very much GrassValley_PS!
        Cineform: unsolved. Yes, i have Cineform codecs on my machine. I try to uninstall end reinstall the codecs.
        Thanks!
          "Cineform should work once you activated QT in Edius."
          Is that true if the are Cineform AVI files as opposed to MOV? I have not tested it recently.
            That's why I asked :)
