[EDIUS 8.3 WG] Bugs
    Edius WG 8.30 on Win_7 Prof: everything ok.
      Originally posted by DanyPPC View Post
      No way, I deleted the following folders:
      C: \ ProgramData \ Grass Valley
      C: \ Users \ Dany \ AppData \ Roaming \ Grass Valley
      I started Edius, set the display of the effects palette in small text mode. I closed Edius, I rebooted and the effects palette is empty, unless you set the display to large icons mode.
      I installed Edius 8 (8.3WG) for the first time on a clean system 64 Seven.
      I am quite experienced on the PC, but this is a program bug that is boring me.
      could it be that a divider is collapsed to the left, see if you can find and drag
        WoW Anton !!!!
        That was the problem !
        I hope someone of programmers at G.V. fix the dissolve transition above.
        Thanks, for all and for your support.
        You are a Great.
        Danilo
          What do we learn...?
          ....not everything that looks like a bug is a bug ;)
          Nicola
          defacto.media
          www.defacto.media
          __________________
          Win10 SSD || Intel(R) Core(TM) i7-6820HQ || Intel(R) HD Graphics 530 / NVIDIA Quadro M2000M || 64 GB RAM || Edius 10 WG
