Inside are two things - the plug-in, and a config tool for the actual hardware board (it should detect the driver you've installed).
You want to extract the Canopus subfolder and put it into the Photoshop CS3 plug-in subfolder. (i.e. c:\program files\adobe\adobe photoshop cs3\plug-ins\canopus\)
Hey, great! Thanks! Oh, and one more thing. I've got the 1.20 video out plugin installed. Will the output plugin for After Effects 7.0 work with AE CS3?
Ok use this ZIP file.
I try to use this file with AE7.
I followed the described procedure, but it seems no good
Is it normal ?
Marc
System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5 Edius in France
I think the file posted by KH is for Photoshop CS3 NOT After Effects. You can download the AE7 working output plugin from the Canopus website - I think it is version 1.2.
Hum ... it's OK for AE7,
but for Photoshop 7 , the TV stays black (there is a video signal).
The plug-in "Canopus VideoOut.8be" is well installed in PS7.
A special setting to do in PS7 ?
Marc
Call me dumb, call me stupid, but I've installed this plug-in as per Mr. Sparkle's post and have found the Export>Canopus video out in CS2 as per Claire's post...how does it work with Edius 4.54? I thought it was meant to send a still pic from within Edius to Photoshop for adjustment then export back to Edius but my pics open in Paint - how do I change it?
Thanks guys
Don
