Hi folks,
I got a problem and I need your help.
I have a project.I want to export aaf file so that I can edit with Adobe premiere pro.But I find Edius say the projet's fps can'nt match up to the timeline footage.
I try to find the solution on Internet but seems like no good anwser.
If I change the fps, which should be changed? footage or project?
If I create a new porject, how can I import the previous project or sequense into the new one.
I export aaf or edl many times, but it still doesn't work.
Would be great to have your opinions on this.
Thanks a lot.
________
Edius 6.5 Chinese interface
Windows 7-64bit
8GB RAM
Intel(R) Xeon(R) CPU, [email protected]
Thanks a lot.
________
Windows 7-64bit
8GB RAM
