Here's a curly one... I've rang a couple of fellow Edius users and support in Australia on this and can't find a solution.
Problem:
Trying to drop a video transition on 2 overlaping video clips in a video track and the transition refuses to apply.
To be more specific, I pick up the disolve transition [or any transition] and whilst holding down the left mouse button [LMB] over the 2 overlapping clips, the transition greys out the tail of the first clip and the top of the second clip [indicating I'm on target and it's going to work] but releasing the LMB forces just the transparency level in the top or tail of one of the clips to change, thus I get the first clip going from 0% transparency to 100% transparency then the second clip cuts in.
Points to note:
1 .In application settings, extend clips when applying transitions is OFF
2. this is a multi sequence project and I have no problem like this in the other sequences
3. I was happily working in this sequence and applying trans to clips for hours before I finally hit this brick wall.
4. When trying to apply the transition dialogue appears in the dialogue field in the bottom of the timeline that says:
"The data necessary to complete this operation is not yet available"... WTF?? I feel like I'm in the twilight zone 8-)
5. I've also tried selecting the 2 clips video channel and hitting the default transition hot key {[CTRL] P} but to no avail 8-(
My Temporary solution.....Making a NEW sequence and copying all the clips from this seq into the NEW seq, I can happily apply transitions... no worries. This is my ONLY work around so far.
Maybe the problem is painfully obviuos to someone out there but I'm baffled.
Is this a bug?
Does/has anyone else experienced this?
Am I going crazy [err on second thoughts ignore that question.. I've been editing too long, I know I'm crazy already 8-) ]
Any solutions?
Thanks in advance
Problem:
Points to note:
Is this a bug?
Any solutions?
Thanks in advance
