We have down loaded several files from our P-2 card using the source browser using add and transfer. Now clips are showing up as sequence clips? What are sequence clips?
Sequence Clips
Sequence Clips
tdtinker
New system: Asus X99 i7 6900K 3.2GHz, 32GB DDR 4 Ram, GTX 1070 Edius 8.5
www.actvp.comTags: None -
P2 has a file size limit of 4GB with Fat32
so if you shot something that was longer than 4GB, it will become a spanned clip because EDIUS correctly joins all clips that belong to the recording between camera start and stop
so all is perfectLast edited by antonsvideo; 09-08-2016, 02:48 AM.Anton Strauss
EDIUS X WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro -
They are called spanned clips. The 4G that Anton mentioned is a Fat 32 limitation. It generally equates to about 8:30 in HD footage. If you put that clip in the timeline and double click it, a new sequence will open with the separate clips broken out.1: Intel 13900K, Asus ROG Z790 Hero, G. Skill Trident Z5 6400 64G DDR5, Asus Tuff Gaming GeForce 4070Ti, WD SN850XNVMe 1T, 4T (2), Seagate IronWolf NAS 7200 14TB, Lian Li Galahad 360, Aja Kona 4, Super Flower Leadex Platinum 1600W
2: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200Comment
I edited my post to use the correct wordingAnton Strauss
