It appears that "Import Sequence" fails since I updated to v8.22.623. Seems to import all of the media into the Project folder, but ends up with a "Failed to copy file." pop-up....so no sequence opens.
"Import Sequence" with Edius Pro v8.22.623
Try right clicking on the "root" folder in the Bin and choose Import. Navigate to the project .ezp file select it.1: Intel 13900K, Asus ROG Z790 Hero, G. Skill Trident Z5 6400 64G DDR5, Asus Tuff Gaming GeForce 4070Ti, WD SN850XNVMe 1T, 4T (2), Seagate IronWolf NAS 7200 14TB, Lian Li Galahad 360, Aja Kona 4, Super Flower Leadex Platinum 1600W
2: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200 -
Thanks for the quick response.
That does work, however I have 2 problems:
1. This way does not transfer (copy) the media into my current Project folder.
We archive projects to a server drive and need our media transferred to
our local drive.
2. This way brings in all of the media from the archived project. The main
reason I use Import Sequence is to only bring in media and sequences that I
want. ie; A project has 12 sequences in it with 25GB of media and I only
want 2 of the sequences, I save the archived project with just the 2
sequences I need and start a new project and use Import Sequence to
import just the 2 sequences. That way I only get the sequences I want and
the 2 sequences may only have 4GB of media associated.
The Import Sequence function has worked great for the last 5 years. Wanted to check the forum before calling support.Comment
What options are checking when you try the Import Sequence?1: Intel 13900K, Asus ROG Z790 Hero, G. Skill Trident Z5 6400 64G DDR5, Asus Tuff Gaming GeForce 4070Ti, WD SN850XNVMe 1T, 4T (2), Seagate IronWolf NAS 7200 14TB, Lian Li Galahad 360, Aja Kona 4, Super Flower Leadex Platinum 1600W
2: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200Comment
can you confirm that the PC used for importing sequence has Quicktime player installed, and in system settings, importer exporter quicktime, the box is tickedAnton Strauss
Seems to work fine here.1: Intel 13900K, Asus ROG Z790 Hero, G. Skill Trident Z5 6400 64G DDR5, Asus Tuff Gaming GeForce 4070Ti, WD SN850XNVMe 1T, 4T (2), Seagate IronWolf NAS 7200 14TB, Lian Li Galahad 360, Aja Kona 4, Super Flower Leadex Platinum 1600W
no errors were reported
is EDIUS on the same PC that was used for the original project? or are we talking different PC
what still formats are used if any?
what file format are the video clips?
any third party titles used such as NB or Vistitle?
any clips using third party filters, transitions, keyers?Anton Strauss
Well, apparently the "Fix-it" Fairy stopped by over the weekend. This morning I have successfully imported 5 sequences from previous projects. Can't explain why it's all of a sudden working. I had been having the error for 2 weeks.
Thanks for the responses....Comment
Have an old project with say 10 sequences and I need to import 2 sequences into a new project. 'new' project settings match the 'old' project.
From the 'new' project I go file->import sequence. There is no option to select the sequence. Seems I can only select the project containing the old sequences so go ahead.
All 10 sequences appear in the new project complete with thumbnails. The actual files are not transferred into the new project.
Is this correct?
How should I proceed to have just the required sequences and the matching media in the new project. Both projects on the D: drive. Edius 8.22.312Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_StudioComment
Is this correct?
now start the new project, import sequence and choose the original project fileAnton Strauss
Thanks Anton,
Makes perfect sense to close unwanted sequences.
GeoffSys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
