I've got a lot of UHD footage that I'll be dropping into an HD timeline. Most of this will be cropped / zoomed / panned. I'm assuming I'll be using the layouter to do this, but I'm wondering if there's an effective way to manage the workflow?
Specifically, is there any way to simultaneously view both the cropped version and the original? Kind of like the way Photoshop handles non-destructive crops: you can toggle between seeing the entire image with the cropped-out area ghosted to grey, or switch to viewing only the crop.
My sense is that with the layouter I'll have to click into each layouter effect to see the pre-cropped original and to make adjustments. Is that the case, or is there an effective workaround or setting I'm missing? Thanks.
