Exporting Uncompressed v210 AVI and file is not compatible with Adobe Premiere
  • Exporting Uncompressed v210 AVI and file is not compatible with Adobe Premiere
    I exported a file in Edius using the Uncompressed v210 AVI 10bit YUV codec. The file works fine in Edius.
    The person who wanted the file uses Adobe Premiere and says he can't open the file. So I figured he just didn't have the codec since he doesn't have Edius or use Grass Valley products. So I sent him this:
    GV_CodecOption_7.31_2939_Setup.exe
    He installed it on his computer and Premiere still won't recognize the file. But it does play on his computer using VLC player.
    Can anybody tell me what's going on? What codec does he need? Any suggestions?
    V210 has nothing to do with GVCodecPack!
    Ask him to install BM- or AJA-driver (the codec is part of it), so V210 shouldn't be an issue.
    Andreas
    Andreas Gumm
    post production / authoring
    Windows 7 Ultimate,
    GV hardware: 3G Storm
    PC 2
    GV hardware: HD SPARK
      Ask him to install BM- or AJA-driver (the codec is part of the it), so V210 shouldn't be an issue.
      Andreas
      Thank you Andreas! Do you have a direct link to the codec download? Many thanks!
        Sorry, can't help better.
        Just look into the support download areas (AJA Kona video card uses it for sure).
        I'm using the LAV codec package. Other users do not suggest to install any codec package for maybe good reasons.#
        I personally have no issues here regarding decoding any file.
        Andres
        Andreas Gumm
        Windows 7 Ultimate,
        PC 2
          Originally posted by More4K
          v210 AVI should work in Premiere natively. No need to install anything.
          Is it valid for CS6 too?
          Andreas
          Andreas Gumm
          Windows 7 Ultimate,
          PC 2
            Should be- v210 is generic for many apps.
            Maybe this works for AVI flavour in most apps.
            The MOV flavour needs a codec package at all.
            I can't sort out at the moment if my Premiere CS6
            could decode it natively due to the installed codec pack.
            Andreas
            Andreas Gumm
            Windows 7 Ultimate,
            PC 2
