Growing delays when switching from and to Edius
  • Growing delays when switching from and to Edius
    As soon as projects reach a certain - but rather modest - size there is a delay when switching applications (e.g. from Edius to Photoshop, AfterFX or even QuickTitler). The larger the project the longer that delay.
    Is this a RAM problem? I have 1GB on that Edius machine and wonder if an extra GB would help. Or are people with 2GB having this problem also?
    I have also this problem with 2 GB Ram.
    Then 3 GB ? More ?
    Marc
    System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
    Edius in France
      Not the answer I wanted to hear. It is not a RAM problem then. I hope it gets solved sometime, because I switch to and from AfterEffects/Photoshop etc a lot.
        Just curious .... are running a virus protection software on your editing machine and is it running when you edit.
        I use AVAST virus protection and I was recently having this problem as well. I finally figured it out. It was AVAST running in the background. Now if I am working and I have trouble switching between apps I just remember to disable AVAST and bam...instant switching. Something in the way it is running in the background really slowed app switching. I only notice the problem though if it is Edius I am switching back and forth between. All other apps play fine with it.
          Indeed I my testing the Application switching delay happens when:
          1 Anti virus is running (Avast is the one we tested)
          2 Notebook or PC is in some kind of Power saving mode.
          Sr
            Wow, I have AVAST as well. Will try this asap. Not in the studio yet, but that could be the problem. Let you know how it goes.
            EDIT/UPDATE: yes, turned AVAST off and it switches apps much faster. Thanks, I should have tried that before....after all it is one of the golden rules right ;-)
