How to lock an audio clip to a V/A clip
  • How to lock an audio clip to a V/A clip
    Hi
    This would seem such a simple procedure, but I cannot see how to do it.
    I have a clip on the VA track of someone walking with synchronous traffic sounds. I have spent some time synchronizing footsteps from an effects file onto the 1A track. Now I want to lock the VA clip to the effects clips so that they cannot be accidentally unsynced. I cannot link the clips because they are on different tracks. Grouping the two clips is not the answer as even grouped clips can be pushed out of sync in some circumstances. I cannot lock the tracks as I have more work to do. I know I could print this short sequence to file and re-import it, but surely there must be a simple quick way.
    Use a nested sequence. Make a new sequence- paste the clips (video and footsteps) in that sequence- now bring that sequence back in to the main project. Nothing can move out of sync.
      Thanks DigitalDave
      Yes that works fine, but I find it rather strange that there is not a option such as Select clips, Right click, Lock clips. It would seem such an easy, quick way to do it.
        But that's what group does and I'm not sure how you can knock a group out of sync any easier/harder than you can with an AV Clip.
        I use nested sequences regularly where a section maybe undergoing changes and updates, the only down side is no waveform but that is "workaroundable".
        I would also say that I sometimes do lock tracks and then other clips go on the non locked tracks ie where a shot needs to come in on a music phrase (beat).
          Originally posted by DigitalDave View Post
          ...I use nested sequences regularly where a section maybe undergoing changes and updates, the only down side is no waveform but that is "workaroundable"....
          I use nested sequences very often and am frustrated that there is no waveform (Premiere pro from Adobe and other NLE have that implemented - of course).
          Can you give me some tips to "workaraound" that weakness.
          // All I know is to copy the audio into the sequence which use the nested sequence. But that is sometimes a crazy method.
          BTW: This missing basic feature (missing since years!!!) is only one of other missing basic features which I can not understand why the developers are so stubborn this not to implement (since years!!!).
          The normal common sense tells that this feature is missing. Each tong finally has indeed two jaws.
          I really dont understand that logic.
          And in addition: If one requests such missings he is told to report that via the GV-Forum. Fine - but if after YEARS such ridiculous sloppiness
          are not corrected, when will they be corrected ???? 2050 or 3010...
          Regards kurt
          SW: WIN-10/64 PRO (21H2-19044.2006), Firefox u.a.
          NLE: EDIUS-X(10.33.9356)-WG; RESOLVE-18.0.4.0005 Studio​​
          // Read > Test > Understand
            I agree it is a PITA. I do not use often for that very reason. When I need to I add two VA tracks. Place the sequence in one and a HQ file of the same thing above. Sync up using the HQ waveforms then mute that track. I can now make changes to the sequence and know it is in sync if they are not major. In my case it is usually syncing two performances of the same show and wanting to get an edit from one into the other. Waveforms are essential for this and a real defficiancy of using sequences.
            Ron Evans
              @ Kurt I simply make a wav file of the sequence and link them on the main timeline. I use this when making musical promos from multicam shoots, so each section may be a sequence. I then use this wav and seq to sync to a master (re-engineered) audio track - nothing clever but only takes seconds and works.
                I have used this in Premiere and I find it very hit and miss. It takes time to generate the waveform and it disappears as soon as you change the original sequence. All of this makes sense if you think about it but are the reasons it has not been implemented in EDIUS, it is not as easy as you think.
                  Thanks for your tipps - kurt
