Audio waveform in Edius 6.08
  • Audio waveform in Edius 6.08
    Noticed for the first time ever that the audio waveform is not acting correctly. The waveform shows a spike but the sound happens roughly 15-25 frames thereafter. Anyone have ideas? Should I uninstall Edius and reinstall?
    Thanks,
    Ara
    close EDIUS and delete all audio wavefrorm files that belong to your project, then start EDIUS and let it generate new waveforms
    also, make sure you have not applied an audio/video offset (delay or advance)
      Thanks as always Anton. That was the trick! All is good now.
      Thanks,
      Ara
        One more issue. What would cause an out of audio synch on a timeline on one project only? This is an old project with VHS and mini DV footage? Worked fine originally but now timeline audio is off on certain clips but not all?
        Thanks,
        Ara
          can you inspect the timeline audio? does it have red out of sync indications? is the audio wav 48k? or mp3?
          are you using V+A tracks or VA tracks for the problem clips?
            Attached is a pix for you to view.
            Thanks,
            Ara
              that only shows me lots of missing clips
              can you inspect the out of sync clips to see if they are 48k wav or mp3
                I always convert mp3 to wav. There are no mp3 on timeline.
                Thanks,
                Ara
                  maybe all the offline clips cause playback issues?
                  can you show a screenshot of the start of a clip that has sync issues (not the whole timeline) use the windows snipping tool
