I want to start with a new version of Edius (Edius 8 Pro). I don't want to upgrade. I have the licenses on order. How do I get Edius 8 Pro so that I can install it, and apply the licenses (20 licenses)? Does Edius 8 Pro require you do download the trail version first or can you just get a version of Edius 8 Pro and install it on all the computers, then apply the licenses?
Edius 8 Pro
you will need to create an user ID ETC and register it then it will appear in your registered products list wher you can download it.
Dont confuse this with the old system this changed in Edius 8
Using the trial has given problems for SOME USERS
Dont forget your ID.
Pro needs an internet conection to periodically validate the licence. Workgroup doesnt
http://forum.grassvalley.com/forum/s...ad.php?t=35631Last edited by John Lewis; 07-06-2016, 08:12 AM.System Asus WS Z390 Pro MB, CPU i9 9900K, 32gb 3000mhz Ram, EVGA GTX1070TI, BM IP4K Win 10, BD Burner 1 Evo 840 and 4 Hotswap caddies
There's no difference between the trial version and the paid version other than trial version needing to connect to the internet each time you open it and it stopping working after 30 days They are exactly the same installer, installing the same program, only the serial number denotes what parts get unlocked, so if people were having problems with the trial version then they would also have problems with the full version as they are the same program.
There's no need to make an ID just to download Edius itself, only if you want the DVD Menu backgrounds as they aren't included in the main installer. You can download the main installer from the trial download page and install it from that, you just can't use it without either a trial or full serial number.Last edited by Adbear; 07-06-2016, 08:09 AM.DVC Built Clevo P775DM3-G Laptop with UHD screen, 7700K [email protected], Geforce GTX 1060 6GB GPU, 500GB M.2 Primary, 1x 480GB SSD, 1x1TB M.2, 1x 2TB 5400RPM Video drives, external Blu-ray Optical
You can only get the trial if you make and EDIUS ID and the trial can only be used once. The computer needs to go on the internet every time the trial is used.
So in this case, when you are asking about multiple licences, you could probably install EDIUS on all your machines but you will only be able to actually use the trial on one of them - the others will not let you pass the "enter your user ID" screen.EDIUS silver certified trainer.
If you have installed it on multiple machines , go to the license manager (red icon on the notification are of the windows task bar. Select online activation , enter the serial number. Your commercial version will get registered with your ID.
If you activate them all you can manage them from one ID .
But the trial version is one machine per ID isn't it? I have to admit I never tried deactivating the trial during the 30 day period and putting it on another machine.
I do have several commercial licences on one EDIUS ID, so that definitely works.EDIUS silver certified trainer.
