DVD Creator Export Problems with Edius 4.54
  • DVD Creator Export Problems with Edius 4.54
    I've tryed Edius 4.52 and it's work fine (for DVD with Title and Chapter Menu Exporting).
    Now i've installed the new 4.54 and I find this problem....
    I've ceate a double sequence movie and i need to export that on DVD.
    - If I use DVD Creator with only one SEQUENCE, without any Menu (Title or chapter), the program work fine..
    - If I use DVD Creator with two SEQUENCE, WITHOUT any Menu (Title or chapter), the program work fine..
    but...
    - If I use DVD Creator with two SEQUENCE and Menu Title, one second before compression ending, the program tell me: INSUFFICENT MEMORY and stop the procedure....
    How can i solve my problem?
    Thanks and bye, Max
    Max,
    How long is your total program? I think 1:20 is pushing the limit.
      Originally posted by Rusty View Post
      Max,
      Absolutely no...
      I've use 10 second clip for each sequence for a total of 20 seconds video...
      The problems isn't connected to the leght of the final video...
      Bye, Max
        Find a Bug in DVD Creator
        I've solved my problem and I've find a Bug in DVD Creator!!!
        The problem are made ONLY if i create new sequence inside a BIN and after drag the sequence in the Timeline...
        In this case, DVD Creator don't recognize how many title numbers are present in the project... and if I add more sequence or single video in DVD Creator, the program crash before finish the compression and write: "INSUFFICENT MEMORY"
        If I create new sequence from Timeline Menu, the program work well without problem!!!!
        Bye guys!!!
          Good find!
          I'll reformat this post and place it in the known issues/workarounds forum!
