Suggestions for quality settings
    OK, so it's just not my system?
    The MPEG codec is available in other resolutions (i.e.1920x1080i), but I can't capture SD input from BM shuttle at that resolution. So, the only option is GV. As pointed out, it's a good codec, I was just trying to save some files space for unimportant VHS tape archiving.
    Thanks for all the suggestions. Live long and prosper.
    Edius 10.3 Pro, Intel i7-5820K 3.3GHz, MSI X99s SLI plus MB, 32GB DDR4 mem, Nividia GTX 760, Win10 Pro x64, BM Intensity Shuttle for preview & capture.
    New to Edius - came from Liquid, before that 16mm film. I've been filmmaking since watching ST TOS first-run live on B&W TV
      I only have MPEG available when using resolution formats that aren't useful
      e.g. MPEG shows up when resolutions are PAL & 50Hz, or NTSC and 1920x1080. But that doesn't help as tEdius won't capture unless the BM is set to the input format 720x486 59i.
      Does it make sense that MPEG is not available at the only format that is useful?
        Originally posted by DaveL
        Thanks all for input. I have an issue however.
        When I look at the compression settings, the only options I have are Uncompressed, GV HQ, and GV HQX. No MPEG
        I wanted to try MPEG per Anton's suggestion, it's not there.
        Suggestions on why that codec is not on the list for BM shuttle at 720x480i?
        720x480i is DV format, capture to that via firewire
        NTSC VHS is 720x486i
        I can confirm that mpeg custom and mpeg IMX are missing when selecting NTSC, may be a bug or feature? I will try and find out
        they are all there when selecting PAL, see attached
          This is the same on my system. MPEG custom is only available for PAL formats.
          When working with NTSC, MPEG & IMX are NOT available.
          Bug, feature? Thanks for info.
