Hi, I'm capturing VHS tapes that are of so-so quality using HQ via blackmagic intensity USB. It's basically working fine, BUT I'm trying to set the quality settings (the HQ settings on the device preset menus) to be "appropriate."
What I mean is that I don't want to use the disk space to capture high quality HQ, but use the custom settings to lower the quality as appropriate for so-so VHS tapes and lower the size the captured files.
I'm having a hard time understanding what the 2 quality settings do. I can change their values and get different quality captures, but I can't find anywhere what the values mean and what "reasonable" settings might be.
Does anyone have suggestions as a starting point, or can point me to some detailed information on these settings? Thanks
