Problem adding clip to TL
  • Problem adding clip to TL
    Hi folks,
    Can you please tell me what I'm doing wrong? I am trying to add a clip to the timeline, but when I drag it from the bin window an X appears and doesn't let me place it. The only place it will go is on the V1 track, but then all I get is the audio. I'm sure I am just missing something, but what? Thanks for your help!
    Cheers!
    Mark
    Mark
    What are the clip properties?
    Right click the clip, select Properties, select the Video Info tab... Provide the information from "Size" down.
      Thanks Bryant - the info is:
      Size 720x480
      Aspect Ratio 0-9000 (4:3)
      Field Order Bottom Field First
      Stream Type Canopus
      Framerate 29.79
      Thanks!
      Mark
      Mark
        Did you map that V1 track by accident?
          Sorry -I don't know what that means? I'm pretty new to Edius and comming from DV Storm 2 with it's ease of use, I'm struggling a lot to understand many things with Edius.
          Mark
          Mark
            right click the little "a" on the left of timeline and then click clear all tracks, then all will be perfect
              Mark
              As Anton said, you will see an 'A" next to the icon of a waveform and a "V"
              next to the icon of a filmstrip. If you want to use the Video on that track
              select the "V" do the same for the "A" if you want the audio to follow.
              If for some reason you see this happen during editing, look for those 'clues'
              to help you find your video and audio.
                Oh dear - I'm feeling more and more dumb the more I work with it! I've looked and looked for the "little A" that you speak of, but can't find it anywhere??? Any other clues? Sorry guys, please don't give up on me!
                Mark
                Mark
                  Look at the picture.
                    When I do the right click my options are:
                    Set Clip channel
                    Height
                    Add
                    Duplicate
                    Move
                    delete
                    Rename
                    That's not what you show?
                    Mark
                    Mark
                      Put the mouse pointer in the area where one of those a or v are and right clik. It does not matter if they are active or not.
                        Okay I've found the "a" you were talking about - I right clicked it, went to clear all tracks, but it's still the same i.e. can't bring video clips into timeline.
                        Any other ideas would be appreciated!
                        Mark
                        Mark
                          Is the add video button active on the time line?
                          (Does not have red line going trough it)
                            Duh - no it wasn't, what a plonker I am! Thanks for your help.
                            Mark
                            Mark
