I saw a post in another forum where someone was using Photoshop CC 2015 to fix the bubble horizon issue when editing from a DJI Phantom 3 Pro Drone. I have the same drone and was wondering if there is any type of lens adjustment or lens adjustment filter I can use in Edius for the same problem? I'm sure since the other person was using Photoshop he most likely was working with stills. I'm working with filmed footage so I'm sure it's different. I don't have nor use anything by Adobe. Thanjks.
How to do lens adjustment for Phantom 3 drone with Edius?
David
DMS Films, New York
Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.comTags: None
NewBlue have a filter in their "Essentials" filter set called "Lens Correction"
Also Prodad Mercalli V4 has lens correction for a number of cameras but it is not adjustable Only works with EDIUS 7.5 and above (64 bit) Mercalli V2 does not have the correction (32 bit)
Worth a try
Download GoPro studio, i cant advice however if the files will be compatible
Also if using some plugin products some files may need removing from the directory you installed it intoSystem Asus WS Z390 Pro MB, CPU i9 9900K, 32gb 3000mhz Ram, EVGA GTX1070TI, BM IP4K Win 10, BD Burner 1 Evo 840 and 4 Hotswap caddies
Frankly I found all the available plug ins and tools to do this pretty poor.
If you want to do it properly, use AE and Saphire see an earlier post here:
http://forum.grassvalley.com/forum/s...light=fish+eye
Paul :-)Edius Edits at: http://www.vimeo.com/user781619/videos
Give these ProDad products a try:
http://www.prodad.com/home/products/...rnen,l-us.html
http://www.prodad.com/home/products/...2316,l-us.htmlEdius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Each program will correct the fish eye to a degree. For a quick fix, and don't use the default setting but rather the 'reduce fisheye' effect, the NB one works and is a plugin for Edius. It's convenient and will work for most cases.
I have AE, Prodrenalin, and NB Lens Corrector. Of the 3, AE is the best. It isn't a one click solves all approach, but it does the best job.
If you are using a Go Pro, Go Pro Studio 2 can fix the fish eye and export to file prior to importing it into Edius. I don't have this installed due to the reported Waterfall error. I don't know if that is still an issue.
The problem with the 'auto fix' programs is the zoom level. You can adjust that to a point in those programs. In AE, you have full control over the image.
What it will come down to is how exact and quick you want the fix.Jerry
I apologize for such a late reply weeks later. Had a family emergency and just getting back to work. Thanks to everyone for your advice.David
DMS Films, New York
