Making a DVD with 16X9 and 4X3 on same disc.
  • Making a DVD with 16X9 and 4X3 on same disc.
    I want to make a DVD with a menu that will allow you to choose your format, meaning 2 chapters on the same dvd but one is widescreen (16x9) and the other is 4x3 version. Since you cannot have 2 sequences within the same project each with different screen formats, then what do yo do?
    Sounds simple i suppose, just import a 4X3 video into a 16X 9 project and choose "make a DVD" but I'm not sure this is the right way. Do I stretch the 4x3 to fit the widescreen or just leave it with bars on the sides?
    Thanks for any input.
    NLE: PC, Gigabyte Motherboard with E6850 Core 2 Duo CPU @ 3.0ghz. 4Gb Ram. GRAPHICS: NVIDIA GeForce GTS250
    DRIVES: 4TB raid 0 array connected to AMCC 3ware SATA controller with 518mb memory. Other Drives: Seagate & WD 7200rpm 1TB each
    SOFTWARE: Edius 5.5, Adobe Encore CS4, Photoshop and After Effects CS4.
    making a DVD with 4:3 and 16:9 is easy with DVD Lab Pro, it requires multiple VTS with a VMG menu, but I totally don't recommend it
    simply make it 16:9, it will look fine on 4:3TV (letterboxed, people are used to it)
    be sure you set the 16:9 flag when you do the encoding
      Well the video was originally shot as 4x3 and I re-edited it with added graphics and pics to make a 16x9 but wanted both versions available on a single DVD. I guess another option would be Double Sided DVD and put each version on each side? hmmm. I was just hoping there was a work around.
        I would use a double DVD case and make 2 individual disks
        on the other hand, why not make only 4x3 since this is the source format, 16:9 users can select normal view and they will see it pillar boxed, I watch all my MASH and for those who remember BONANZA episodes that way
          M*A*S*H was great - Pillarboxed is fine :) Much better than stretched or zoomed 4:3.
          I agree most with this suggestion, Let the DVD player do the work.
