Yeah not nearly as easy,but no choice.
What bout pip
I would have to disagree with that.
What bout pip
Use the Layouter instead. It is worth the effort. And actually, it is not difficult to use at all. You can scale, pan, crop, zoom and turn within one tool. If you like to, you can do this in 2d, but also switch to "3d" to turn pictures in a kind of 3d room.
You can make PiP as you did before with the 3d PiP: place to videos above each other. On the upper one, go to Layouter, scale down the picture size and place it anywhere. You can make keyframe animations as you could in the 3D PiP tool.
Try it! It is like changing from a bycicle to a motorbike: seems complicated at the start, but you will soon like the greater opportunities!
Intel Core i7-7820X ---- Noctua NH-D15S ---- MSI X299 GAMING M7 ACK ---- 64GB RAM 2666-15 Corsair Dominator Platinum ---- 500GB Samsung 960 EVO M.2 (system SSD) ---- 512GB Samsung 960 PRO M.2 (data SSD) ---- Aorus Nvidia GTX 1080 Ti ---- be quiet! SILENT BASE 600 Case ---- be quiet! Dark P. Pro P11 850W ---- Win10 Pro ---- Edius WG 8.53.2808
hi guys you can use 3d pip in other way in edius 8 also.we made some of the preset file in which user can use pip with in out and with frame like edius 6..no9 need any thirdparty plugin..if anyone want to see can send mail us on [email protected]
