Hi guys, I have a sudden onset problem with my Edius 6... I have a couple projects on newer drives that open right up. But most of my projects won't open at all. It just get the frisbee all day. Not sure what to do. I went to reinstall, but I see it wants to uninstall first, and I'm afraid of losing my projects. Any ideas?
Edius 6 won't open projects
where are the troublesome projects located? on the same new drives? If not, can you copy them to the new drives with Win Explorer and then try again
also, which version EDIUS6 do you have?Anton Strauss
This is version 6.05. I've tried copying the old projects to the new drive. no dice. I got one opened today but can't do anything with it. It just shows the frisbee. I was going to reinstall, but I didn't know if that would blow out my existing projects. Also thinking about upgrading, but I'd like to be sure I can jump to 8 Pro from 6.05
uninstalling and re-installing does not harm your projects
I would do that and then apply the free update to 6.08
If you go to EDIUS8, be warned that it is a 64bit software and all plugins you may have now won't work until you upgrade them all to 64bitAnton Strauss
Now it's worse!
I reinstalled and it won't install the driver for the product key. I can't use Edius at all now. Guys, I really need some help here. I'm a TV editor and I can't get into any of my projects. Here's the error message: "Devise driver software was not successfully installed." The device is HASP HL 3.25 That's the little green USB key. I've tried three times, no luck
Can you not restore your system drive to a date prior to these problems?
Maybe you have a windows' backup' or an image of your system that you have forgotten about. If so you will be up and running in minutes.
If you have an SSD for your system drive restore may not be an option but if you have a HDD there should be several restore points available.
Sorry I cannot be more helpful.Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
Read this http://forum.grassvalley.com/forum/s...ight=HASP+3.25
Also sometimes just moving the dongle to another slot is enough.
you can try the dongle driver on the installation CD, see attached video
or download the latest
http://www.safenet-inc.com/support-d...tinel-drivers/Attached FilesAnton Strauss
