Frame Rate for shooting in different countries?
Andreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
software: Telestream Switch, DTS-HD MAS, Dolby Media Meter -
Originally posted by More4KFrame dropping looks terrible.
If anything you wan too rather repeat frames/fields (pulldown approach) rather than remove frames.
But here repeating fields or frames makes no sense in a 29.97 -> 25 process.
I've just expected some bad "conversion" shemes with unwanted frame drops
when someone states a magical and easy fps conversion.
AndreasAndreas Gumm
Windows 7 Ultimate,
PC 2
software: Telestream Switch, DTS-HD MAS, Dolby Media MeterComment
For example, if your master project is 23.98 and you shoot 29.97p for slow motion, when you play the 29.97p footage back at the project framerate of 23.98, you get a slow motion speed of 80% (23.98/29.97=0.80....). If you shoot 47.96 (48fps) you would get a 50% slow motion speed.
This method avoids frame interpolation and blending in creating the slow motion in post.
So the answer to your question is, you need to do the math to figure out what slow motion speed you want, and adjust your framerate to get it. otherwise you have to settle for the adjustment in post.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX Titan Black 6GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX and one on Intel HD4600).Comment
Originally posted by More4KIdeally you don't want to do it this way, but play existing frames at slower rate. In Edius this is done by changing source fps to your timeline fps and than dragging source to timeline.
If you drag some high fps source to your e.g. 23.98p timeline and than play with speed (or not) you will have interpolated frames (or skipped/repeated). You would need perfect: original/new fps=n cases to avid any conversion problems.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX Titan Black 6GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX and one on Intel HD4600).Comment
I totally understood you Bern, and you are absolutely right. Furthermore, it's the only way to get smooth and un-interpolated (no frame blending) in Edius natively. Andrew already knows this, I think he may have simply misunderstood your post.
Is your Robot three laws safe?Comment
Originally posted by More4KYes :)
Not sure are how I have read it, but you've suggested the same.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX Titan Black 6GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX and one on Intel HD4600).Comment
Yes, I am the said Avisynth novice, and indeed have found the fps conversion using this method to be outstanding - better than any software conversion I've seen. As good or better than a lot of the hardware converted stuff I've been given over the years. I'm definitely a believer now, and a daily user.
I tried out Episode trial version as well, but couldn't get very impressive results out of it, or any consistency. And at $1,200 a license (pro), that's not too inviting. I understand that, say, 50i to 60i is a very complex conversion to make, which is why there is hardly any software out there to do it well (no frame blends, no nearest-frame glitches). But More4K's Avisynth method does indeed deliver the goods AND it enables conversion directly from Edius timeline! Or using a third party application, whichever is more convenient.
As mentioned, I have zero prior experience with dealing with Avisynth or scripts in general, but had little trouble getting my sea legs and getting stellar fps flips right in my edit suite!
For anyone who deals with a lot of mixed fps materials, or delivers content from PAL to NTSC world or vice versa, would we well advised to check out this option. I only wish I'd found this out ten years ago - a lot of my stuff would have looked so much better...Desktop: Edius 8.50 WG/Win 7 Pro/HP Z620/Intel Xeon E5-1620 @ 3.60GHz/16GB RAM/NVIDIA Quadro 4000/Storm 3G
Laptop: 8.50 WG/Win 10 Home/ASUS ROG G751/Intel i7-4710HQ @ 2.50GHz/16GB RAM/NVIDIA GeForce GTX 970MComment
Thank you still taking notes from the comments herewww.skysimonephotography.com
www.skysimonefilm.com
www.facebook.com/skysimonephoto
Laptop:
ASUS - 17.3" Gaming Laptop - Intel Core i7 - 16GB Memory - NVIDIA GeForce GTX 1050 - 1TB Hard Drive + 256GB SSD - Metal Star Gray
Edius Pro 9 Windows 10Comment
