Recently was asked to re-edit some footage that was on a DVD having been copied from tape at sometime in the past, probably using something like a Panasonic or similar VHS to DVD combo. Although I have successfully done this on my own produced DVD`s I encountered a problem with this job in that although I could import the VOB files from having them copied onto my hard drive, they would only play for around 10 secs & then the picture would freeze although the timeline cursor would continue.
I tried rendering but no good, then for some reason I though, let`s see if tsMuxer will see the files, which it did, so I then "Muxed" them and to my delight, they played perfectly in Edius 6.08! So I thought I would post this in case it helps anyone else :-)
