I need to setup a project so my reporters can simply import clips with atereo audio and have them appear on a timeline with 2 separate mono centered tracks. Right now i must go into the clip properties and select which audio track i want to use.
Need help setting project for dual mono imported tracks.
Set the mapping of the timeline to mono.
If this is how you always edit it is best to modify the project preset so that every project/sequence starts with those settings. In EDIUS 8 you can also save project templates.Attached FilesLast edited by GrassValley_SL; 02-22-2016, 12:21 AM.
Steve has explained how to do it. This is how hundreds of broadcast stations do it. Are you dong news editing at a station or are you a Production type that is submitting commercials or programs for air?1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
