Problem importing files from sony dcr-dvd908
    Hi Mr Sparkle,
    Thanks for your answer, it seems to work.
    I'm still testing it because I need to go trough my friend and as I'm in the Philippines and he's in Switzerland, it makes it a bit difficult.
    It looks that to import the footage with DISCcapture I need to format the DVD in VIDEO mode and finalize it before being able to import. The problem then is that when I import the files to Edius, it doesn't recognize the 16/9 format and I have to manually change every footage, is there a batch process to do it in many files at the same time?
    If the DVD is formated in VR mode, I can import the files with DISCcapture but the files are still shorter when imported to Edius.
      If the DVD is anamorphic widescreen, the clips should come in properly flagged at 16:9.
      If not, try Restream to fix the flags.
