Sync-Lock Markers
  • Sync-Lock Markers
    I'm using the trial version of Edius 8. The sync-lock markers icon does not show up on task bar. Where can I find it?
    Theo
    hello Theo ...
    hmmmm.. you mean with "task bar" the "Mode Bar" ... om left /top from the timeline windows ??
    It is not set by "default" ... need manually work ...
    I give you a picture, in the hope, my pictures are better than my english...
    ____
    Hans
      Thank you. The good news is I found it, the bad news, it does not work. Where do I find the menu for enabling and disabling the different markers. Or where is the sequence marker pallet to put into preview window?
      Thanks,
      Theo
        Found it just after I posted it. Can I default the markers to be unselected?
        Thanks,
        Theo
          Thanks,
          Theo
          yes and many other things
          Using the new EDIUS 7 or EDIUS 8 Sequence Marker Ripple Function to allow Markers to ripple with the edits
            Thank you. Now you better live town before I have more questions. I will tray To find as many tutorials as possible.
            Theo
