I export AAF from EDIUS 8.11 and import it to PE 3.5 using "original clip" option in Edius. PE syncs great. I then export the synced AAF from PE and bring it into EDIUS... the new sequence is NOT synced like in PE. Everything goes off some frames all over the place. Any ideas why?
EDIUS 8.11 AAF PE to EDIUS not synced
Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...Tags: None -
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD. -
That's where I got my information on how to do this and has my problem.
I also read about exporting to PPRO or Media Composer and then from there to Edius but that's too tedious.
I thought maybe because I'm importing AAF with only sound, PE is not recognizing that my footage is from a 25fps project and is making an NTSC timeline - which may be the cause of sync problems.Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...Comment
Did you find the problem? I upgraded to 8.11 but have not had to sync yet with PE 3.5. I was able to use the workflow just fine but now it seems I may run into some problems. I do not shoot 25fps though. Let us know if the problem is still occuring.Comment
Not yet. What I'm doing now is in PE, I click SHFT-(DOWN-ARROW) to jump to next clip, and input the CTI time from PE to EDIUS and move the clip over to the correct place. Edius is smart enough so if you are on a 25fps timeline and try to jump to 2:30:26, it will jump to 2:31:00.Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...Comment
What's frustrating is that when exporting to AAF from EDIUS 8.11 and syncing in PE 3.5, Pe syncs perfectly almost every time! But when you export from PE back to EDIUS 8.11, the sync is off... the clips still have the almost same "shape" as they should be but each clip is off by a few seconds.
If ALL the clips were shifted the same amount, you could just shift all together and done... problem is that first clip can be shifted 1:02 seconds... second clips 1:12 seconds... and so forth. So each clip has to be manually shifted back to place in EDIUS.Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...Comment
I contacted RED-GIANT for a plugin. Maybe if there would be enough demand, they'd make one. So go ahead and contact them and ask for a plugin.
Get access to all our filmmaking and motion graphics tools with Red Giant Subscription. Get started with Trapcode, Magic Bullet, VFX, Universe and Pluraleyes.Attached FilesGigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...Comment
I did a test this morning. I have Edius 8.11 and PE 3.5. I used the workaround like I have always done and everything synced fine for me. If you haven't tried the workaround give it a try its not that bad. Actually it is pretty quick. I too thought it was a hassle but tried it once and really did not mind it.Comment
I did a test this morning. I have Edius 8.11 and PE 3.5. I used the workaround like I have always done and everything synced fine for me. If you haven't tried the workaround give it a try its not that bad. Actually it is pretty quick. I too thought it was a hassle but tried it once and really did not mind it.Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...Comment
I have used the Adobe Premiere XML option (I believe the second link) and it has worked countless times for me just fine. I start with Plural Eyes, sync everything up, then import the XML file into EDIUS. The only thing I wish EDIUS would do is maintain the audio tracks as stereo. It reads the audio of stereo files and duplicates them, with left and right.Comment
