No Quick Titler GUI
  • No Quick Titler GUI
    Hi
    I have Edius Pro 7.4. I'm either doing something silly or I have a fault. After several years of using Quick Titler with no problems, suddenly, when I select Title to go on the title track 1T, it appears on the 1T track, and Quick Titler is also on the Task Bar, but there is no Titler window. It's not hidden behind the main Edius window.
    I have tried it with several different projects, and also rebooted the computer, all to no avail. Any suggestions would be welcome.
    this means the titler is open outside the visible desktop
    press Alt+Space and while holding press M
    then use the arrow keys on your keyboard to bring it back into view
      Yet another of your great tips on "hidden" features, Anton
      Very useful for Windows in general.
      Thank you
      Regards
      Douglas
      Creator of Video Tutorials for mere mortals at https://www.gaijin-eyes.com
      Main System: EDIUS WG 9, Asustek Intel Z370, i7-8700K @ 3.70GHz, 32GB RAM, GTX-1080Ti, BMD Intensity Pro 4K, Windows 10 Pro
        Brilliant
        Thanks Anton
        That worked a treat, thanks for your help.
