SoundSoap+5 not showing in effects
  • SoundSoap+5 not showing in effects
    I have EDIUS Workgroup 8 (8.10.188) on my Windows 10 Pro 64-bit machine. It works pretty well. Occasionally I need to clean up the sound, so I have a SoundSoap+5 VST Plugin set in the EDIUS System Settings. It is not showing up in the AudioFilters palette as I believe it's supposed to.
    Background:
    I just updated to SoundSoap+5 - installed and activated - it runs OK in its stand-alone application - I need it to work as a VST Plugin.
    I've unset and set the VST Plugin setting for EDIUS 8 twice. It is pointing to the correct folder with the SoundSoap+5 DLL. I've restarted EDIUS and rebooted Windows more than once.
    I last used SoundSoap 4 with my previous EDIUS 7 and maybe 6. I've never used SoundSoap+5 within EDIUS.
    I'd appreciate any assistance getting this working.
    Did you go into Settings>System Settings>Effects>Vst Plug-in Bridge and add the location of the VST? After setting this you will need to restart Edius to activate it.
    Also, is Sound Soap 5 compatible with Edius 8? I didn't see Sound Soap 4 listed as a compatible plugin here:
    I just installed the trial and tried to link it within Edius 8.1. No luck. Here is a screen shot for .VST location:http://www.grassvalley.com/assets/me..._CompGuide.pdf
    The only catch is that the .VST folder is empty. So, no way to link.
    I would contact Sound Soap and verify whether is is Edius 8.1 and Windows 10 compatible.
    I've now tried to install the trial of 5 onto:
    1. Edius 8.1 on Win 10
    2. Edius 8.1 on Win 7
    3. Edius 7.51 on Win 7
    I didn't see either a 64 bit or 32 bit VST loaded into the Sound Soap location as seen in the screen shot above.
    Definitely contact Sound Soap.
      OK, you gave me a hint and now it's showing and working! One thing I had figured out, though I didn't use the knowledge correctly, was that when I active SoundSoap+5 with the code they sent me, it then copies the DLL to the expected place. Much more important is to point EDIUS to the correct version; 64-bit in this case. When that gets done, all is well.
        Have you had a chance to see if the new version suffers from the 1024-sample audio delay problem that affected Sound Soap 4?
          I didn't receive a code for the trial. That would have been important info to know before I started.
            I'm going to answer my own question...
            I took the plunge today and purchased the upgrade from SoundSoap 4 to SoundSoap 5+, and the delay is still there -- very annoying.
            It's still a useful tool for noise removal, giving good results with little work and at a reasonable cost. But you either have to use the standalone application, or use the Audio Offset feature in Edius and sacrifice a second or so of the beginning of the clip to fill the SoundSoap sample buffer.
            I also own WaveArts Master Restoration Suite, which is more powerful and has no audio delay. I don't understand why SoundSoap still suffers from this problem (especially since it didn't exist when SoundSoap still came bundled with Edius).
              Plug-in Soundsoap 3
              I have done as you describe, it does not work for me, "VSTPlugins" taken in "Effects", I do not know how to get it in place? SoundSoap 3 worked in Edius 6.5 & 7.xx!
              Did you go into Settings>System Settings>Effects>Vst Plug-in Bridge and add the location of the VST? After setting this you will need to restart Edius to activate it. Grateful for proposals.
              [ATTACH]14761[/ATTACH]
              Windows 10 PRO - 16GB DDR4 Ram - 16TB - Intel Core i7 7700K 4.2GHZ, 8MB Cache - SSD 128 -SSD 250GB - NVIDIA GeForce GTX 1050Ti - EDIUS 8.52 - AE CS4 - 1 LG W2252 - 1 Panasonic 243V - 2st Panasonic HD HC-X920 - 2st Panasonic DVX100B
                In the 'Effects' section you should have 3 options, 'After Effects Plug-in bridge', 'GPUFx' and 'VST Plug-in Bridge'. You have to add audio plug-ins into the 'VST Plug-in bridge' not the 'After Effects Plug-in bridge'
                Just installed the trial version of Soundsoap 3 and Edius 8.11 sees it perfectly when added into the VST Plug-in bridge then a restart of Edius
                  maybe 8 Pro does not have a VST plugin bridge as seen as missing in his screenshot? I can see it here in 8 WG
                    If you 're running Edius 8.1 Pro, do you have all 3 items mentioned?
                    AE BRIDGE
                    VST PLUGIN
                    GPUFX
                      Certain unsupported VST plugins make the VST entry disappear.
                      It is best to cut the vst plug-ins from the location set as default. Add them one by one to find out which one is thr culprit.
                        I deactivated my Workgroup version and activated the Pro serial to test and yes, VST plugin bridge is there, so it must be a bad VST somewhere seen by EDIUS
                          Thanks for checking.
                            SoundSoap+5
                            Installed SoundSoap +5 today and to my great disappointment after many hours of testing can not I get audio and video sync?
                            I tested the "Audio Offset" both + and -, nothing succeeds ????
                            Feels like "USD 128.05" is wasted money
                              the way to work with soundsoap is to print to file, audio, PCM wav
                              then place the wav clip below existing and line up waveform with original, then mute original
                              I use Wavearts Master Restoration, it causes 0.0000% delay and has many options not found in soundsoap
