Edius 7.51 update problems
  • Edius 7.51 update problems
    Hi! Problems with upgrade to Edius 7:51
    There will be a message.
    "Updater can not be running in your system.
    This setup will not Proceed."
    There have not been any problems in the past with Win. 8.1
    I have Win.10, today, it can be the problem?
    Windows 10 PRO - 16GB DDR4 Ram - 16TB - Intel Core i7 7700K 4.2GHZ, 8MB Cache - SSD 128 -SSD 250GB - NVIDIA GeForce GTX 1050Ti - EDIUS 8.52 - AE CS4 - 1 LG W2252 - 1 Panasonic 243V - 2st Panasonic HD HC-X920 - 2st Panasonic DVX100B
    Edius 7.51 is not Win 10 certified. Only Edius 8.x is Win 10 compatible.
      Is Edius still running in the background?
        Yes! Edius 7,50.228 runs in the background
          You need to close Edius before you can update it
            Get the same message?
              I had a comparable problem with the updater. The updater would not run under win10. But the full installer did run under win10 (1511), so that was for me the solution. All my files and settings were kept, no problem. Until now I did not experience any problem with Edius 7.5 or 7.51 under win10, certified or not. (Most programs that run under win8.1 don't give problems under win10).
                Yes, in some cases it will work. That said, I would make a clone of your system just to be safe.
                  Had a similar problem awhile back.
                  http://forum.grassvalley.com/forum/s...ad.php?t=37083
                  Can you extract the update file with say '7-Zip' and the use the setup.exe file found in the extraction folder to update E7.
                  Have now found this problem on two further W10 machine albeit without Edius being installed. Just testing the extraction provided by GV Seems W10 is too fussy.
                  Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
                  Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
