Shooting with the new Sony A7S II and wondering if it can be imported into a Edius 6.5 bin and timeline?
Xavc-S into Edius 6.5
Originally posted by dlmonak View PostShooting with the new Sony A7S II and wondering if it can be imported into a Edius 6.5 bin and timeline?
Now we moved to TMPEGEnc video mastering works 6 - still using MPEG 2 - 80MBps closed GOP. If clips are short you could re-compress to HQ or HQX.
We have not tried rewraping to MOV - it could possibly also work http://hdcinematics.com/convert-V2.html1st System: Edius 9, TMPGEnc VMW6 & AW5, ASUS P9X79, Core i7-3930K, Intel SSD 330 180GB, GeForce GTX 570, Corsair Graphite 600T Mid-Tower, Sony Optiarc AD-7280S, 16GB RAM, 12TB , Canopus ADVC-300, 2nd System: Edius 9, HP ZBook 17 G3, i7-6700HQ CPU @ 2.60GHz, 16GB RAM, 512Gb SSD, 1 TB HDD. Cameras: Panasonic DVX200, Fuji X-T3, Sony RX10
For us the reason behind using MPEG2 is that it seems to be more responsive on our hardware, especially in 1080 50p multi-cam mode.1st System: Edius 9, TMPGEnc VMW6 & AW5, ASUS P9X79, Core i7-3930K, Intel SSD 330 180GB, GeForce GTX 570, Corsair Graphite 600T Mid-Tower, Sony Optiarc AD-7280S, 16GB RAM, 12TB , Canopus ADVC-300, 2nd System: Edius 9, HP ZBook 17 G3, i7-6700HQ CPU @ 2.60GHz, 16GB RAM, 512Gb SSD, 1 TB HDD. Cameras: Panasonic DVX200, Fuji X-T3, Sony RX10
Rewarp XAVC-S (MP4) to MOV
How do I remap the MP4 to MOV?
Is this simply changing the file extension? Or is there a software utility for this?
I have used AFX to convert my files to Edius HQ so far.
I do the same thing with my RAW BMPCC files.
Just seen this post and was wondering I have just updated my Sony HXR-NX3 with Version 2 Firmware which now enables it to record XAVC S Files and have not had a chance to test it, the question is I have Edius Workgroup 8.1 will this format work without converting it in version 8.1 workgroup?
If it isn't any different than the non firmware upgraded codec it will be accepted. The performance will depend on your system.Jerry
Edius 8.1 WG will be fine with XAVC-S it will be a little more resource hungry than your AVCHD that you were using prior to tha firmware upgrade.Main Editor - Edius 8.53 AdobeCC Mini Monitor 4K Intel X99P SLI Intel Core i7 6800K CPU Gigabyte GTX980 SanDisk Ultra Video SSD 1XINTEL System SSD 16GB Kingston DDR4 2400 RAM VisTitle 2.8 Onboard Sound 10GBE LAN WIN10Pro 64bit
www.nakedeyedv.com
XAVC-S into Edius 6.5
Actually my original question was getting XAVC-S into Edius 6.5,
I have Edius 7.4 on my other workstations and they all handle XAVC-S without any issues. So it should work fine in any version of Edius from 7.4 and up.
However my home system is stuck on 6.5 (until I build a new NLE PC for versions 8). So I was hoping to do some work at home with my XAVC-S files.
You will need to download the AVCHD File Conversion Utility (AVC2HQ) found in the registered users section under (General) Utilities.
Convert to HQ or HQX and you will be off and running.Jerry
