How to create Print to File Presets
  • How to create Print to File Presets
    I'm constantly using the same export settings to create either DVDs, Blu-ray disc or MP4s for YouTube. At the moment I'm having to manually add settings for these in the Print to File box. I see that there are 3 options that I could be using:
    1. Current Default
    2. Recently used
    3. My presets
    I'd like to know how to add to these, particularly My presets, so that I can have these 3 separate export settings available with a click rather than recreating them each time.
    Thanks for your help.
    System:
    Custom build PC: EDIUS 9 Pro; ASUS PRIME H310M-A Motherboard; Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz; 16GB Corsair DDR3 RAM; NVIDIA GeForce GTX 1060 6GB; 500 Watt PSU, 1 x 250GB SATA2 Drive for System, 1 x 1TB and 1 x 2TB SATA2 drives for video footage; Pioneer BDR-207DBK 12x Internal BD-RW Burner; Windows 10 64 Bit
    UK & Ireland Cameraman and Video Editor
    Click on the Disk icon at the bottom after setting your preset
    This then saves to my presets under the name you exported
      Doh!!! Never saw that. Thanks for pointing me in the right direction.
      System:
