Audio crossfades removal
  • Audio crossfades removal
    I'm reworking an Edius project which has audio cross fades between all the clips on the VA track. I now need to remove the cross fades but unfortunately they were added in FIXED mode not EXTEND and as a result removal leaves the clips with shortened audio sections.
    I usually deal with this by simply dragging out the audio parts while holding Alt key but this time there are just too many clips, plus I have more timelines like this to deal with. Does anyone know of a better way?
    Claire
    I think think if you turn on the "Extend Clips when applying Cross fades" it will work in reverse. I.E. it will extend the audio when deleting cross fade.
    Edius 8.5WG, Vistitle 2.6, DVC Built: Intel S5520 motherboard, 2 x 2.40Ghz E5530 quad core Nehalem Xeon with HyperThreading, 12GB DDR3, Samsung SSD 850 EVO 250GB, 2 x 1TB Samsung 32MB Cache SATA drives, nVidia 9800-GT 512MB PCIe, HDStorm Plus, LG BH08LS20.AUAU 8x Blu-Ray Writer, 700w ThermalTake W105RB quiet power supply, Windows 10 Pro 64 bit.
