I have to mix 3 camera's (multi-cam edit) with different file-types. I'm wondering which project settings I should use. I'm not used to do this. I usually only work with my amateur-camera. So your advise is more than welcome.
You'll find hereby the data I found after importing all clips in GV Browser.
All cam's PAL 1920x1080 format, 4:2:0
Camera 1 (Canon 100?): 25p, MOV, CBR, [email protected]
Camera 2 (Canon ...?): 50p, AVCHD, H.264/AVC, VBR, [email protected]
Camera 3 (Canon EOS 5D mk III): 25p, MOV, CBR, [email protected], YUV 8
I guess I better convert all clips to HQ of HQX?
They used a flash to enable me to synchronise the footage ... not easy I guess but feasible ...
I'll also have to synchronise this with seperate audio. All without common timecode. Fortunately the musician (my son) will help with audio synchro.
I'm looking forward to your comments!
